Old 09-10-2005, 01:08 PM
First Hummer is off the scale
I just wanted to let you guys and girls know.That when I installed the SMA sport exhaust, I also removed the heat shield from the original exhaust just above rear axle and intsalled it on SMA with some metal hose clamps.I figured it was there for reason so I should put it back on.Make sure you put this on first before final install,not after like me.The heat shield just needs a little coaxing then remove metal strap.
Old 09-10-2005, 04:11 PM
hmrlvr's Avatar
hmrlvr hmrlvr is offline
Hows the new exhaust?
WWW.BCBI.COM
Old 09-10-2005, 04:14 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by hmrlvr:
Hows the new exhaust? </div></BLOCKQUOTE>
I like it alot better than the flowmaster i had on it.There is no inside cab noise like the flowmaster.Very happy.
