Old 05-25-2007, 07:49 PM
HUM GOOD's Avatar
HUM GOOD HUM GOOD is offline
HUM GOOD has a little shameless behaviour in the past
Default Installing new thermostat-question
to install a thermostat, how much of the antifreeze should be drained? completely? Can it be installed without draining?
Old 05-25-2007, 08:17 PM
tomp's Avatar
tomp tomp is offline
Default Re: Installing new thermostat-question
I did it by removing passenger side fender well plastic and pulling hose. I tried to catch the fluid so I could re-use it, but lots of black stuff came out and I only had a few thousand miles. Decided it wasn't worth it and put in new AF.
Old 05-25-2007, 08:54 PM
HUM GOOD's Avatar
good point - Thanks
Old 05-25-2007, 11:08 PM
IRA51's Avatar
IRA51 IRA51 is offline
I always flush and change the fluid when I change the T stat. that Dex Clog is some strange stuff ,can't decide if its good or not .
A government big enough to
you have.
-- Thomas Jefferson
