Old 07-23-2007, 07:10 AM
Alt-F4 Alt-F4 is offline
Alt-F4 is on a distinguished road
Default Cognito leveling kit
Hi all.
I searched the site and didn't see any posts about it so I will ask.
Is anyone running the Cognito leveling kit? The one with the drop down A-arms. If so how do you like it? Have you noticed any real articulation benefit from it as opposed to just cranking up the T-bars?
I am debating on this mod and would love to hear some input on the pro's and con's. Thanks
05 H2 SUT
68 M715
71 J2000
74 J4000
05 Explorer Sporttrac Adrenelin
Old 07-23-2007, 03:45 PM
tomp's Avatar
tomp tomp is offline
Default Re: Cognito leveling kit
don't know anyone using the kit yet....
you don't gain any articulation benefits from the kit, nor any more travel. It simply moves the range of travel downward to compensate for cranking the TBs.
Pros - Allows factory ride quality after cranking TBs and keeps alignment within spec after having an alignment performed. Can easily replace balljoint without replacing entire upper contraol arm. Same arms can be used to add dual shock setup, providing you also purchase their dual shock loop.
CONs - Will need longer shocks or extensions, may lose factory warranty for the OEM control arms you removed. However, if cranking the TBs caused excessive wear on the balljoints, you may not have a warranty for the upper control arms anyhow. Not really any major cons to doing this kit other than it's another $450+ to spend.
Old 07-23-2007, 09:00 PM
Thanks for the quick reply Tomp .
So by using the kit it basically centers the wheel travel in relation to the stop and makes less wear in the ball joints when the T-bars are cranked? Instead of bringing the stop and ball joint the max positions when the T-bars are cranked for the leveling?
Sounds like a good mod and I have added it to my list. Thanks for helping clear it up for me.
05 H2 SUT
68 M715
71 J2000
74 J4000
Old 07-23-2007, 10:15 PM
tomp's Avatar
No, it does not center it in the stop, but rather moves the droop stop on the Upper Control Arm higher to allow it to droop more. This is the steel metal we are talking here, and not the foam stop. The new upper control arm is made to allow proper alignment and also puts the ball joint where it should be - at the right angle.
Old 07-23-2007, 11:50 PM
After laying under my truck and looking at it closely I understand now. Thanks for the answering my post
I am going to get the leveling kit.
05 H2 SUT
68 M715
71 J2000
74 J4000
Old 07-24-2007, 03:57 PM
Alan06SUT's Avatar
Cool. Please take some pics of before and after if possible. Are you going to install it yourself?
Old 07-24-2007, 11:49 PM
I will take pics no problem. I am on my way back east this week and have set up time in my friends garage to do some mods with his help. It will be a month or so until I will be able to get to modding my truck. Work before play . I have a list of things I am going to do. I went from full on lift to all the trimming down to more warranty friendly mods since I will still have 50k left on my warranty once I get back east. After the warranty runs out I may go even farther with modding, not sure yet will have to see how things go with this round of mods. I will post what I am doing with picks once the fun begins! Thanks to all of you guys / gals on the forum for lots of info and help on deciding what to do.
05 H2 SUT
68 M715
71 J2000
74 J4000
