Old 08-07-2007, 02:52 PM
It\'s a Dry Heat's Avatar
Default Wheel balancing system
Does anyone know if this balancer works with H2 wheels? I've got wheel weights on the outside of my stock wheels. Trial Duty had a balancer on their site but took it off when it was found it would not fit on H2 stock wheels.
http://www.balancemasters.com/home.html
Old 08-07-2007, 04:34 PM
tomp's Avatar
tomp tomp is offline
Default Re: Wheel balancing system
Call them and find out for us. I'd like to know if they'll work as well.
FYI, the issue is not with the wheels, but the brake calipers
Old 08-08-2007, 09:18 AM
I went to website and it explicity tells how it works with Hummers and has a pic of a H2.
My guess it works and says it can help with braking.
TAZ
Old 08-08-2007, 12:18 PM
flyin6's Avatar
flyin6 flyin6 is offline
flyin6 is on a distinguished road
When I switched to 37's on my crawler truck, they installed some sort of a powder substance inside the tire. Can't tell you what it is called, but it is added in measured amounts, remains moisture free and balances the tire from the inside. I can attest that it worked! Might try that instead of some expensive mechanical device
07 H2 black de-chromed SUT
04 Z71 Suburban
03 Z06 Vette 440RWHP
01 SAS Supercharged Tundra
