Old 08-24-2007, 11:34 PM
ELIO ELIO is offline
ELIO is on a distinguished road
Default WATER PROBLEM
I would like to know if anyone has experienced the same problem as I have and how did you solve it.
I just purchased a 2003 H2 Hummer, but seem to have a little problem with it.
My problem is that whenever it rain I have large puddles or accumulation of water on the driver's side carpet, and can't seem to solve the problem. So if anyone can help, I surely appreciate it.
Thank you!
Elio
Old 08-24-2007, 11:38 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
Default Re: WATER PROBLEM
Check all your seals... windshield, sunroom, front/rear passenger doors, you may want to pull the side panel trim (along floor) and the kick panel plastic, this may give you a better idea where its coming from. Hopefully you can get it straightened out, Good Luck
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 08-25-2007, 12:55 AM
Thank you!
Elio
Welcome to the forum.
If you use the Search function, "leak", like I did, you'll find all your answers readily available.
Congrats on your choice of truck.
http://www.elcovaforums.com/forums/s...earchid=122921
Old 08-25-2007, 01:45 AM
cajon cajon is offline
cajon is on a distinguished road
Change your clearance lights,new design.
Old 08-26-2007, 05:21 AM
pdsq99f4 pdsq99f4 is offline
You could also just reseal them with clear silicone sealant or replace them. I'd also check the rubber harness where the wiring goes from the body to the door. Seen a couple leak from there. If someone has been in there before, they may not have gotten the connector in correctly.
Old 08-26-2007, 07:11 PM
working Hummer's Avatar
Nothing a ladder and a tube of sillicone can't handle.
