09-10-2008, 07:24 AM
When the WORST HAPPENS to Your Baby
I saw this in another forum, customer and 4wp employee going at it
YOUR COMPANY HAS DESTROYED AND IS DESTROYING BRAND NEW 4X4'S ALL ACROSS THIS COUNTRY WITH NON CERTIFIED MECHANICS WHO ARE IN THE THE TRAINING PROCESS THAT LEARN ON OUR VEHICLES TO GET THEIR LICENSE
LOOK AT THE AGES OF THESE PEOPLE, where's the senior tech??????
The Pro Comp lift kit does not fit, no problem we
will just grind and spray paint
Lets make the engine into shrapnel
Anybody want to commit Odometer Fraud on your
leased vehicle, 4WP will provide you with a zero mile odometer NP
Thinking you just bought a brand new exhaust, NOPE 4WP installs a USED One
4WP will sell anything, no matter if its garbage, re-welded
Rear Diff skid plate, NP, lets pinch the rear brake so the brake stays ON
YOUR BOSS GREG ADLER NEEDS TO COME CLEAN, AS HE WAS WAS INVOLVED IN THIS FROM DAY ONE, TRASHED A BRAND NEW VEHICLE, DESTROYED IT AND SAID
F' OFF, "We have unlimited resources to crush you."
WHAT 4WP IS TERRIFIED OF
Federal Trade Commission
Internet Fraud Complaint Center
Office of Defects Investigation
FLORIDA VEHICLE REPAIR ACT
09-19-2008, 03:38 AM
Re: When the WORST HAPPENS to Your Baby
09-19-2008, 01:37 PM
wow. Never been to a 4wp's before my bro had his lift installed by them on his first truck in houston.
----------o-o-o-o-
[[_]|[]|[][___  ]
[---\-|-----[ -OIIIIIIIO-]
"(O) ) ---- (O) )/"H2"\) )
09-22-2008, 11:30 PM
09-30-2008, 06:42 AM
this was just posted in a jeep forum
All my experience only applies to 4WP in Miami gardens...
The sales guys... Mike, Jason, and manager Zeus.. all great guys. I wouldn't hesitate to BUY parts from them.
The shop... maybe nice guys, but idiots wrapped in a moron would be putting it lightly in my case. They would probably do better if they had a well seasoned and experienced shop forman to work under and who could check out their work before it leaves.... that act alone would be a full time job with what they let leave there.
The Reader's Digest version is I have a 2008 Unlimited Rubicon.. I bought and had installed at 4WP in Miami
The major stuff
- Pro Comp Long Arm Lift and all that goes with that which is a list in its self
- J.E. Reel 1350HD shafts front and rear
- 37" Mud Grapplers Plus Rims and spacers
- 5.13 Gears
-Fox Steering Stabilizer
The parts above alone cost over 10k
Plus so many other "little" things I can't even begin to list... the receipts I can actually find surpass 15k.
What was done wrong...
-They "Lost" 2 of my factory Rubi Shocks and tried to pass off 2 "X" shocks as the ones they took off. Rubi shocks are red, X shocks are white.
-My rear track bar was put on backwards
-When lift was installed I asked to have my breathers extended.. the rear was put actually lower than the stock height and the front wasn't touched.
-One of my Fox Shocks FELL off
-Tires rubbed on control arms... that's when it was discovered I need spacers.
-Rear Spring was hitting the track bar.. I brought it to them to FIX... see below
-Developed a horrible noise the day I got it back from having 5.13's installed. After 3 days of "diagnosing" was told it was my transfer case. I had 3k on the odometer. This sparked the end of the relationship with me and 4WP. I even prepared my lawyer for a suite because after all my mods Jeep would laugh at me for trying to warranty a T-Case. It was also when I brought it to them for the gears that we noticed my rig was drooping rather severely on the right rear corner.
- Because of the "transfer case noise" it ruined plans, and had me all stressed out. I called Tranny Doc about it and was going to have it TOWED to his shop from Miami. Before going through all that I hooked up with ROCO4X4 as they are a few miles from my home. Turns out the right rear control arm was loose... REAL LOOSE and was basically causing a suspension noise that was telescoping through the rig and out of the T-case. ROCO took less than a day to figure it out.
- I had 4WP warranty me out a set of rear springs as it was thought I had a sagging spring on the right rear. When new springs were installed it still sagged. After further investigation it turns out that SOMEONE had shortened the right rear control arm pulling the right side of the axle forward to get the spring to not hit the track bar . The track bar was also cranked way down and the front left spring was not seated in the perch but riding on it. Basically my rig's suspension was being pulled and stressed so badly that it was collapsing the right rear spring. To fix all this they pretty much just reinstalled my lift correctly relieving the suspension of the stress and now my rig sits perfectly level and rides awesome... the rear wheels are actually behind the fronts!
At the end of the day and to their credit 4Wheel Parts refunded a little over $600.00 to me. Small change for well into 5 digits I've spent there and the aggravation of it all. Not only that, I've spent what they returned to me in towing and what I had to pay ROCO4X4 to straighten the mess out.
I am now so worried about how they may have installed my 5.13's I am actually awaiting the "BANG!" going down the highway.
Until they get a journeymen mechanic in there who knows WTF he is doing, I wouldn't let them put air in my tires.
10-03-2008, 06:35 AM
MANY COOPER--PRO COMP TIRES NOW MADE IN CHINA
