Old 01-02-2009, 09:08 PM
hmmmmr hmmmmr is offline
hmmmmr is on a distinguished road
Default Turn signal/Flasher problem
I've been reading this forum for a couple of years and finally have a problem I can't find any previous answers to.
I have a 2003 H2 with about 65k miles on it. At random, when I try to use the left turn signal, the flashers will activate. Usually, all I have to do is cancel it and try again, most of the time that works. However, lately it sometimes takes 2 or 3 times.
Any suggestions?
Old 01-03-2009, 09:14 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Turn signal/Flasher problem
Flasher module. They dont use separate flashers anymore, integrated into one unit. Its located right behind the left ip fuse panel behind the left knee bolster
Old 01-04-2009, 12:25 AM
Thanks Humtech, that's what I was thinking, but I wasn't sure I wanted to spend $94 on a flasher module without some confirmation.
I put the module in today, and everything seems to work. I'll see what happens tomorrow, after I leave it out in the cold tonight (was -24 F this morning), it seemed to be worse before things warmed up.
