Old 01-13-2009, 09:08 PM
mklonaris1 mklonaris1 is offline
mklonaris1 is on a distinguished road
Default Shifter lock wiring diagram for connector
Can anyone help me? I have the issue where you can't get your key out of the ignition. When I removed the center console cover and low and behold I had a cut wire on the shifter lockout harness. When I tried to pull the connector out I pulled out some of the wires and now do not know where they go in the connector in in what order. There are 5 wires...red, yellow, blk, green/wht and green/blk. The connector has each slot labled with A, B, C, D, E and F.
Help!!
