Old 08-23-2010, 02:18 AM
guruerror's Avatar
Default Line-X Everything
Tired of that cheap plastic...I was...now it's coated in Line-X and I would highly recommend this to anyone who's looking to improve the look, feel and durability of there interior.
I had the cargo area pieces sprayed on both sides to give it extra durability and strength. I've also done the front bits by the hood release latch (and the passenger-side equivalent), sill plates, mirror covers and the pillar trim between the front and back doors...basically everything but the A-pillar and the dash.
I had them test spray some extra dash pieces, but the fit is too tight on some of the parts to get them back together correctly. The next parts will be the door panels...waiting on a cool weekend to effect my mirror repair (old style mirrors that don't retract) which will require me to remove the front panels, then I'll drop them off while I'm working on the mirror issue.
After that I'm toying with removing the fabric from the headliner's 'cardboard' and having them spray it with Line-X Extra grey...but that might not be until spring. They want a piece to test spray.
Just thought I'd share this successful mod.
CNTRY
DTOM
Old 08-23-2010, 05:03 AM
ROUSHDEMON's Avatar
Default Re: Line-X Everything
Wholy crap dude! That looks killer! I had no idea you could line-x thin plastic like that, how much more stronger is it??
And btw, where did you get that divider... door... thingy? Never seen it.
Good job man.
2003 Black H2:
2006 Blue H2:
Old 08-23-2010, 02:35 PM
guruerror's Avatar
All of the pieces feel MUCH stronger...the cargo area pieces (wheel-well covers, and rear door panel) that I had 'encapsulated' (sprayed on both sides) really feel like they could take a beating...whereas before I winced each time something heavy slid around and smacked into them.
The gate is a Precision Pet Vehicle Barrier...you can find them at Petco or on Amazon.
http://www.amazon.com/Precision-Pet-...2570124&sr=8-2
If you install it upside down the sucker works perfect in an H2. The ends of the bars are interchangable and adjustable so you can make it follow the contours of the moldings very well. It keeps those dirty little puppies in the back...in a nice little Line-X box.
CNTRY
DTOM
Old 08-23-2010, 08:12 PM
frontside720's Avatar
frontside720 frontside720 is offline
frontside720 is on a distinguished road
Very intuitive
Not something that would work for my SUT but I still have a general question. By encapsulating the panels you definately made them stronger.
Before spraying the panels, did they have any give? Do they still have give?
I have no experience with line x but I'm just imagine a candy type shel that would chip and crack if hit hard enough or if was bent.
Looks amazing though! Great idea!
2008 H2 SUT Blacked Out
37" Nitto Mud Grapplers on 22" KMC Rockstars, Corsa Exhaust, Leveling Kit, Airraid intake, BlueStar (on order)
2007 Cadillac Escalade on 22's
2008 CBR1000RR
2006 CRF250R
2 x 2008 Sea Doo GTX Limited
Old 08-23-2010, 08:27 PM
guruerror's Avatar
Before spraying they had a good deal of give...too much in my opinion. They always felt to me as if they could be easily cracked if they took a hard blow.
The Line-X doesn't get as ridged as you are thinking...it doesn't chip like a candy shell would; it's got flexibility to it. They still have give but not nearly as much and you can tell that it can take a lot more punishment.
CNTRY
DTOM
Old 08-23-2010, 10:43 PM
Intercooled's Avatar
Intercooled is off the scale
Does the truck sound, feel more solid? Did it help deaden any rattleage ( is that a word?)
2006 H2 SUT Fusion Orange LE
Old 08-23-2010, 10:52 PM
ROUSHDEMON's Avatar
X2!
2003 Black H2:
2006 Blue H2:
Old 08-24-2010, 01:17 AM
snmazer snmazer is offline
snmazer is on a distinguished road
How expensive was it to have that done? It looks awesome!
Old 08-24-2010, 01:37 AM
guruerror's Avatar
The parts definately feel more solid. Everything feels more 'substantial.' It also eliminated all of the squeakage/rattleage (to coin a phrase) from the cargo area. I can't wait to get the door panels done...that's where most of my squeaking comes from.
The whole thing cost just under $1,000. That included:
Rear door panel (spray on both sides)
Left and right rear wheel-well sections (spray on both sides)
Trim above and below the rear door
Trim above the cargo area windows
Left and right pillar trim between second row and cargo area
All four door sills
Left and right pillar trim between front and second row seats
Left and right trim in the front (where the hood release is and the opposite corressponding piece)
Both side mirror caps
Both exterior side vents (just above the hood latches)
Both Predator cowl light moldings (the ones that replace the 'bumps' just outside the windshield)
CNTRY
DTOM
Old 08-24-2010, 02:40 PM
mightyepp's Avatar
mightyepp mightyepp is offline
mightyepp is on a distinguished road
Did you have to remove all the pieces and drop them off? I removed some of the pieces in the past, and a couple of them were a pain getting back in.
2003 Hummer H2
Old 08-24-2010, 02:42 PM
guruerror's Avatar
Yep...took them all out myself. I've had that truck apart so many times I've got it down to a science.
I dropped them off and picked them up a few days later. Everything snapped right back into place.
CNTRY
DTOM
Old 08-24-2010, 03:19 PM
dvl57's Avatar
dvl57 dvl57 is offline
dvl57 is on a distinguished road
How much did all the pieces so far cost you?
It really looks awesome!
Does it smell differently now that those pieces inside your truck?...vs. normally it being done to the back of a truck
Don
2008 H2
Billy Boat Exhaust
Old 08-24-2010, 03:29 PM
guruerror's Avatar
It was just under $1,000 for all the interior pieces (listed above).
The front/back bumpers and the side trim cost me about $600.
The door panels will probably be another $400-500 'cause I'm gonna have them encapsulated too. So I'll have about $2,000 wrapped up in Line-X when I'm done...well worth it to me.
The interior smelt a bit of hot rubber the first day or two...but the parts were still warm when I picked them up. Now (about a week later) it's just the regular ole truck smell...LOL.
CNTRY
DTOM
Old 08-24-2010, 03:40 PM
ROUSHDEMON's Avatar
man that looks pretty sick... good job.
2003 Black H2:
2006 Blue H2:
Old 08-24-2010, 04:07 PM
HumminNBoatin''s Avatar
Man I am totally inlove with the way that turned out..... That is going on my list of (someday) mods! lol
1998 Am General H1 HMCO
Eric@TheHummerClubInc.com
Old 08-24-2010, 07:14 PM
splne1's Avatar
splne1 splne1 is offline
I SECOND THIS!!! That is a fantastic idea!!!
Old 08-24-2010, 10:38 PM
pwrhse2k's Avatar
pwrhse2k pwrhse2k is offline
pwrhse2k is on a distinguished road
Looks good Guru! I see you're out of Gburg...I'm in southern MD (Waldorf). The line-x was a great idea and I'd really like to get a closer look at your work sometime soon if you don't mind.
Reggie
Old 08-25-2010, 12:14 AM
guruerror's Avatar
Reggie
I got a buddy that lives out in your neck of the woods...he's been worrying me to death to come out and hang with him one Saturday. Maybe one weekend in September I'll come down your way.
Your truck looks like a beast...but I got two questions for you:
1. Where did you get that brush guard?
2. Do you ever get that thing dirty? My truck doesn't like to mingle with 'city trucks?' LOL
CNTRY
DTOM
Old 03-15-2012, 03:57 PM
Humvee21 Humvee21 is offline
Humvee21 is on a distinguished road
Nice!
Old 03-18-2012, 07:13 PM
Wink Re: Line-X Everything
guruerror,
how about pictures of how the door panels turned out?
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
