Old 10-22-2010, 04:22 AM
prideandufc's Avatar
prideandufc prideandufc is offline
prideandufc is on a distinguished road
Exclamation H2 for 4 door raptor?
Hello I'm the proud owner of a 2008 H2. I know how weak the front suspension is on these but I don't want to upgrade it with cosmetic parts.
I want about the same capabilities as a 4 door raptor. That would entail what parts and part numbers. Also who would you recommend for upgraded brakes (is brembo the only choice? if so I know they have different quality calipers and I know that their street calipers ARE NOT the same as their RACE calipers. )
I would like to
1. keep the stock look of the hummer ,ie rims
2. Need WAY more braking power
3. keep all the dust out of the cabin (massive amounts of dust coming through vents even on recirculate. Needs Charcoal filter system of some sort.)
4. I live in Vegas is the stock radiator good enough?
5. I know nothing is indestructible but how close can i get with your recommended parts for the front suspension?
Old 10-22-2010, 05:20 AM
seventwozero's Avatar
seventwozero seventwozero is offline
seventwozero is on a distinguished road
Default Re: H2 for 4 door raptor?
Are you trying to build a pre-runner style H2?
The masses will chime in shortly I'm sure but if you don't really need a massive amount of lift you could go with the standard Cognito treatment. Meaning;
Cognito upper control arm kit
Cognito/Bilstein shocks
Cognito sway bar end links
Cognito pitman/idler support kit
Cognito idler pivot kit
Fabtech or Rancho steering stabilizer
Rare Parts or Kryptonite tie rods
I would also buy a set of 'green' torsion bar keys to go with the Cognito UCA kit. If dampening becomes an issue, Cognito sells a hoop kit to run a dual front shock setup.
I can't comment much on the breaks, other than I know of the Brembo kit, same goes with the cabin filter. I would consider an electric fan kit, your radiator should be good considering there are a good amount of guys here that run their trucks in the hot climates, although once again, not totally sure.
2004 white H2 SUV lux
Old 10-22-2010, 06:27 AM
Thanks for the quick response. Yeah I don't need tons of lift. I just want it to be capable of E and E . cause when the **** goes down I want to be able to drive fast maneuver AND STOP like nobody's business! Funny thing about the movies is they never show any stock car in chase scenes lose the brakes or the fluid!! totally unrealistic
Old 10-22-2010, 07:59 AM
Big.Z.hummin's Avatar
Big.Z.hummin Big.Z.hummin is offline
Big.Z.hummin is on a distinguished road
And you drive a hummer why??
Old 10-22-2010, 08:48 AM
Because if Rod Hall can take this thing to baja and monkey stomp the competition. Then to have something as close as possible to his setup would be ideal for me. If its good enough for baja its good enough for me.
Old 10-22-2010, 04:22 PM
Hellz Hellz is offline
why dont you find out what he runs in his H2 and buy it?
im nto sure on the rules, but didnt he run the H2 stock?
so no aftermarket parts? or are aftermarket OEM replacements allowed?
like beefier tie rods? UCA's?
i know he ran cognito parts, but other than that...
Old 10-22-2010, 07:07 PM
Wink Re: H2 for 4 door raptor?
the above mention set up would be good but
run these shock's like rod hall's h2, that's what i have on mine.
2006 Yellow H2 Lux Series
Cognito Steering Support Kit
Cognito Idler Pivot Kit
Fabtech Steering Stabilizer
Fabtech Tie Rods
Power Slot Slotted Rotors
Hypertech Power Programmer
True Flow Foam Air Filter
Old 10-27-2010, 04:11 AM
nice shocks . Hey how do you like your programmer?
------ -----2008 Aston martin Vantage.2008 H2 road armor front Dakar Base Bumper
with Atlas I Guard. 2006 Bmw 330i.
49 Ford F1 2010 Bmw alpine wht M3
Old 10-27-2010, 05:55 PM
i like it.
i run the base 87 tune, it has more pep, and helps the h2 move faster.
Fabtech Tie Rods
