Old 12-03-2011, 02:12 AM
Wibs Wibs is offline
Wibs is on a distinguished road
Default Octane for 2008 H2 with the 6.2 L
Hi, can you damage the engine if you use 87 or 89 octane with the 6.2 L engine, because I heard that premium fuel is recommended.
Thanks.
Old 12-03-2011, 02:43 AM
Indy's Avatar
Indy Indy is offline
Default Re: Octane for 2008 H2 with the 6.2 L
What does it say in the owners manual? The 03 6.0L is set up for regular fuel.
Old 12-03-2011, 04:27 AM
Z06RB's Avatar
Z06RB Z06RB is offline
Z06RB is on a distinguished road
Ed Wallace an auto guru in the DFW area who drives and tests many of the new cars, says that he hasn't put premium in cars in years, regardless of what grade it calls for. He says that you may get slight reduction in mileage and power but it runs fine.
We have run my wife's Lexus on regular for years and it does just fine.
I however, still run my 505hp Corvette and 09 H2 on premium.
Ed Wallace's website is insideautomotive.com
Old 12-03-2011, 02:02 PM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
Thanks.
No, read the owners manual if you have it! The recomended fuel is regular so 87 octane fuel is fine and will not damage the engine. I am on my 2nd H2 and have never run anything but 87.
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 12-03-2011, 02:20 PM
Easy Ed Easy Ed is offline
Out of a 2009 Owners manual, page 5-5
Gasoline Octane
Use premium unleaded gasoline with a posted octane rating of 91 or higher. You can also use regular unleaded gasoline rated at 87 octane or higher, but the vehicle?s acceleration could be slightly reduced, and you might notice a slight audible knocking noise, commonly referred to as spark knock. If the octane is less than 87, you might notice a heavy knocking noise when you drive. If this occurs,use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you could damage the engine.If you are using gasoline rated at 87 octane or higher and you hear heavy knocking, the engine needs service.
Old 12-03-2011, 03:44 PM
StockStar's Avatar
StockStar StockStar is offline
StockStar is on a distinguished road
Gasoline Octane
Use premium unleaded gasoline with a posted octane rating of 91 or higher. You can also use regular unleaded gasoline rated at 87 octane or higher, but the vehicle’s acceleration could be slightly reduced, and you might notice a slight audible knocking noise, commonly referred to as spark knock. If the octane is less than 87, you might notice a heavy knocking noise when you drive. If this occurs,use a gasoline rated at 87 octane or higher as soon as possible. Otherwise, you could damage the engine.If you are using gasoline rated at 87 octane or higher and you hear heavy knocking, the engine needs service.
Sold!!! 2009 H2 SUV Graystone Metallic. Next stop, 2006 H1 Alpha Hard Top
Old 12-06-2011, 05:03 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
In my 2008 I only notice a difference using higher octane in the summer months when temps are really high (especially if I am towing). In the cooler months I notice absolutely no difference. The things I notice with the higher octane is increased throttle response along with quicker downshifting and less overall gear hunting.... truck may also seem a tad quicker but that could just be a placebo due to the slightly better response/shifting.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 12-18-2011, 02:36 PM
mikejr's Avatar
mikejr mikejr is offline
I noticed my 08 ran like crap on regular fuel. So i always ran premium in it and haven't tried regular in the 09. It felt like it was running of 6 cylinders on regular.
2009 H2 Silver Ice LE
Old 12-19-2011, 04:29 PM
ben86's Avatar
ben86 ben86 is offline
ben86 is on a distinguished road
http://www.youtube.com/watch?v=zjZuZjUXU90
i use only 93 v-power.
www.hummertravel.com
Old 12-20-2011, 12:03 AM
[__--MUD--__]'s Avatar
Thats why they gave us knock sensors. I run regular in all the cadillacs in our fleet. No noticable difference in gas mileage logs.
I notice no difference in the H2. My Ram Air Trans Am is premium only.
Old 01-06-2012, 12:33 PM
TGCOFTN's Avatar
TGCOFTN TGCOFTN is offline
TGCOFTN is an unknown quantity at this point
I run Shell V-Power Premium in my 6.0 and my 6.2 Liter. The premium you get better miles per gallon ( you pay a little more per tank, but if your going further on a tank of fuel, it only makes sense )
Not to be rude and no offense in anyway, but if anyone is worried over a few pennies difference at the pump a Hummer is the last vehicle you need to own. While I know those few pennies adds up into dollars, still if thats making a difference in your budget, you should be in a more smaller economy car. I didn't get my H2's for the fuel economy.
Old 01-06-2012, 05:00 PM
glennf1 glennf1 is offline
glennf1 is on a distinguished road
The only thing running regular does is the computer senses knock and reduces the timing a little. You loose a little power but if you are just cruising around and aren't burying the pedal, you won't notice the difference.
Old 02-24-2014, 06:57 PM
KTM640Dakar KTM640Dakar is offline
KTM640Dakar is on a distinguished road
I always run regular in my 6.2L 2008. I had a bad experience with high octane gas once due to water or old gas at a Shell station. Since they don't turn over the high test gas as often I feel like it has more time to go bad and/ or absorb water due to the ethanol they put in it. Besides if you pay 20% more for high test and only get 3% better mileage then you waste money. My H2 has gobs of power so the regular gas has been fine.
