Old 09-29-2013, 01:10 AM
painguy's Avatar
painguy painguy is offline
painguy is on a distinguished road
Default got a 03 helps with some mods please
picked up a 2003 lux model. Would like to lift it 3 inches and put some 37 inch tires on it. Will 3 inches be enough for the 37 inch tires? Also are the torsion key lift kits sold on eBay a good way to go? the rancho and fabtech options are just way to over priced for my build budget. I guess looking for
1. Best lift option for a 3 inch lift
2. best wheel and tire option for this lift. trucj will be a street queen no off roading
3. Any advice on wraps? Thinking of a matt black or a maat dark grey.
Sold
2009 Hummer H2 - LUX -White
2006 Hummer H2- Fusion Orange Limited Edition1998 1998 Hummer H1 open top
2001 Hummer H1 Wagon yellow
2001 Hummer H1 Wagon White
Old 09-29-2013, 01:31 AM
jsbihn jsbihn is offline
Moderator
Default Re: got a 03 helps with some mods please
The Search option is your friend.
Now with that said, I would suggest looking through Egan's write up on his lift.
http://www.elcovaforums.com/forums/s...highlight=inch
From what I know, you can put 37s on your stock rig with little to no clearance issues. Just depends on various things like the width or the wheel offset. Of course to play it say Egan did a 2 inch "mini lift" and when done was able to fit 37s without issue. I think I asked him the cost and I think he told me about 500, but that he already did the rear spring conversion too so that amount wasnt added into the 500.
The best thing to do, IMHO, would be to get with Egan.
Unless he chimes in on this thread.
As for a street queen, ummm well I would say a decent street tire. Given it is hard for me to say because I want a good street tire but I also want something there in case I do take her into the dirt. Personally I get a good all terrain, ie BFG K/Os but then again if you just want street.... well then you could get into something else that would last longer.
As for offset... well thats up to you and what you want. It is also up to you in regards to the amount of steering hassle you have. I mean you havent told us if you want them to stick out, be even with the fenders, look like stock..... etc etc
Anyways I hope this helps
'03 H2 (name: Big Gulp)
Old 10-02-2013, 02:41 PM
iwillnc's Avatar
iwillnc iwillnc is offline
iwillnc is on a distinguished road
37s may or may not rub, there's no telling really until you try.
Some say that 35s rub, whereas on my truck I have plenty of room with 35s
Really just watch your sway bar, if it does rub just don't turn to full lock
Old 10-02-2013, 11:45 PM
LoJac963's Avatar
LoJac963 LoJac963 is offline
Exactly, my stock 35's rub on the passenger side so there's no way 37's would fit stock without green keys, spacers, etc. Other people can cram them in there no problem.
Old 10-02-2013, 11:49 PM
guruerror's Avatar
The stock ATs did not rub for me. The 37x12.5 BFG MTs on the stock rims rubbed at full lock. The same BFGs on Rockstars with a shallower backspace rubbed a tad. Once I got the keys and Cognito UCA kit in there's no rub whatsoever...got me thinking about 38x13.5s now (sigh).
CNTRY
DTOM
Old 11-02-2013, 05:49 PM
USMC_Buckaroo's Avatar
USMC_Buckaroo USMC_Buckaroo is offline
USMC_Buckaroo is on a distinguished road
"...The 37x12.5 BFG MTs on the stock rims rubbed at full lock..."
Ditto on mine. Switched to the milder tread patterned BFG All-Terrain's in the same size and NO rubbing whatsoever. And, like you guruerror, I've looked at 38's since (did this awhile back, and is why my duece still has an MT as a spare ).
Stopped by Discount Tire last Fall and had them test fit a pair of 38" Geolandar M/T Plus's on the front and they looked fantastic! But they DID rub a tad on full (left) lock. But remember, I was stock height...no key lifts or anything.
HTH.
Buck.
