10-31-2013, 07:41 AM
lowering front shocks?
I lowered the 03 h2 with ground force rear is perfect but my front shocks are dead. Looking to replace them with lowering shocks because I lowered front a good 3". But I cannot find any.... Dodge ram lowering shocks look like they would fit.
Or should I replace with stock style and height?
10-31-2013, 01:26 PM
Re: lowering front shocks?
Whatever trips your trigger... Are you going to lift your sports car next?
10-31-2013, 11:23 PM
LOL
10-31-2013, 11:53 PM
Originally Posted by LoJac963
LOL
CNTRY
DTOM
11-02-2013, 12:51 PM
Moderator
MrIgor,
Please understand that, though your question is genuine and I am sure you hope for an answer, most will probably question what you are doing. Remembering that the Hummer was designed to be a "Go Anywhere" type of "Off Road" truck/rig, and most will be using it for that and there might not be much experience with what you are asking. With that said (and the other things), we dont want to run you off because I am sure that everyone can contribute to the community and that is good thing.
To hopefully give you an answer to your question, I would say the following based on my experience building cars.
If you are looking to lower your vehicle, I would go with a true lowering kit that is made for your vehicle. The work is already done for you. Usually the parts are the same price and if for some reason they are cheaper, think of the time and energy you will have to put into it for the retro. Also from my experience, you will want to lower with springs.... not shocks. Springs carry the weight of the vehicle, not the shocks.... those are just used to control the dampening. (no shocks and the car/truck you are working on would pogo continuously). Now if you have done the springs all around and you need a shock with more dampening force/compression and a shorter throw to replace the stocks you have now, you can alway call Tokico, KYB, Bilstein, Fox (or who ever you choose) and ask them what will work. This way they can tell you what will work and what will fit. I figure better to put a little time into it and get it right then to just guess.
I just believe that when it comes to certain things, it is best to let those who know do the calculating for me.
Hope this helps
'03 H2 (name: Big Gulp)
11-04-2013, 04:32 PM
On another serious note...you might want to give these guys a jingle ( http://www.gstyle4u.com/) and ask them for some guidance. I had to deal with them when I was looking for trailing arms...and while I expected a lot of "yo yo" nonsense the guys actually were quite helpful and knowledgeable.
...and they didn't try to force a single piece of chrome on me.
CNTRY
DTOM
11-05-2013, 02:53 PM
MORE THOUGHTS: ...or try looking at 'lowering kits' for a 2500 Chevy/GMC. That should at least give you a good idea of what 'kind' of parts are necessary.
Our rigs might be 'like nothing else' in concept (big, fat, trail-crawling SUVs), but were still built mostly out of cross-platform GM parts; so what you're looking to achieve is not going to be 'impossible' or probably not even that 'impractical' on your wallet (even though I find it terribly impractical in principle...to each his own.)
CNTRY
DTOM
