Old 02-21-2014, 10:21 PM
jsbihn jsbihn is offline
Moderator
Default Shrader valve assist
Anyone know how to remove just the shrader valve out of the A/C fill ports (low side / fill side - is what I am trying to replace)
'03 H2 (name: Big Gulp)
Old 02-25-2014, 04:01 AM
Rico001's Avatar
Rico001 Rico001 is offline
Default Re: Shrader valve assist
are you trying to remove the valve stems or do you want to cut the whole valve out and solder in a new one.
if you want to remove the stems then you will have to "recover" the Freon and use a stem removal tool and screw the out like you would a valve stem core in a tire rim
Old 03-06-2014, 01:59 AM
Moderator
Rico,
Thanks for the response.
The reason for the replacement is because I think after 10+ years it is just weak and slowly leaking. I have put dye in and it looks like that is the only place it might be coming at... so recovery wouldnt be an issue since it is already gone...
So I am not looking to replace the part, just the valve itself. So where would I get one of these tools, the valve and how would I go about doing it (since I havent dont this in either a tire or an a/c setup)
Old 03-06-2014, 03:28 AM
Easy Ed Easy Ed is offline
http://www.youtube.com/watch?v=tW-3MQQs68g
http://www.autozone.com/autozone/acc...ier=487510_0_0_
May just need tightened down, get the tool and see if it will turn clockwise ;-)
Ed
Old 03-06-2014, 03:59 AM
Moderator
I am going to have lots of projects
UGH! too many projects not enough money
