Old 03-11-2015, 03:00 AM
jsbihn jsbihn is offline
Moderator
Default Tires rub - Help
Hey all,
So I got new shoes and socks for my rig. 18x10 -24 offset with 38 x 15.50 tires
The thing is that at full turn they rub the rail.
I am curious if I put a spacer in between the hub and the wheel, would it help in keeping the tire from rubbing.
(I think I got 1/2 inch spacers - pre-ordered just in case)
Do you think they should help?
or will it cause the tires to rub more
'03 H2 (name: Big Gulp)
Old 03-11-2015, 01:59 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
Default Re: Tires rub - Help
Unless you are lifted, you are definitely going to have rub issues with a 38" tall tire..... that is also pretty wide so that is going to be another issue to contend with.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 03-12-2015, 12:52 AM
Camou2 Camou2 is offline
Camou2 is on a distinguished road
The spacers won't help. With that size tire the only solution is a lift.
www.thehummerclubinc.com
2004 H1 Softtop
2006 H2
2008 H3 Alpha
Old 03-12-2015, 12:20 PM
Moderator
I guess what I also needed to add was that I have a 3 inch level lift on the truck too
