Old 12-18-2005, 12:44 AM
brndray brndray is offline
brndray is off the scale
Here a few clips of my latest mod.
http://media.putfile.com/hummerlights-009
http://media.putfile.com/hummerlights-007
http://media.putfile.com/hummerlights-008
I do have some install pics if anyone is interested.
Old 12-18-2005, 01:42 AM
VTSTOMPER is off the scale
Do you have a short?
Just kiddin! On my old motorcycle I put in a Whelen SP650 hide-a-way strobe kit, it looked too cool when I was doing a nice smoke show! It even had strobe patterns that you could pick from!
'05 Stealth Gray SUT
A Mellow Mix of Black & Bling
Old 12-18-2005, 01:49 AM
The vid kinda sucks it was my first try. They are alternating strobes, whelen as well. Not sure that Ill be doing any smoke shows with the hummer but you never know. I found the kit in a box I had tucked away and figured why not? They could come in handy check the avatar.
Old 12-18-2005, 11:45 AM
That's cool! Like the avatar!
I had 6 on my motorcycle, and it was really cool looking. I would turn them on from time to time - but I had hit the switch one time, and this guy in front of me pulled over. I was like - oops...and the strobes were the clear ones, not even the blues.
I had them set up to flash like this:
FRONT:
Left (3 micro bursts)right off
right (3 micro burts)left off
SIDES:
right (3 micro bursts) left off
left (3 micro bursts)right off
BACK:
left (3 mirco burst)right off
right(3 micro burst)left off
All these would be going at the same time. I could also switch from high power to low power! It was pretty cool!
Old 12-19-2005, 12:00 AM
4churchill is off the scale
tough to judge by the vid, but they seem cool...guy I know had stillen do some in his escalade...they are pretty cool
I like the set up on yours...was the install hard?
www.HUMMERNut.net
Old 12-19-2005, 12:58 AM
Here are some shots of my 2000 929 I used to have.
Old 12-19-2005, 01:01 AM
Old 12-19-2005, 02:19 AM
Cool pics vstomper, I assume you did the rear as well? Install on these is not rear difficult. All you need is a power supply, and 4 strobes. I wired the power supply hot, ground and a switch to the strobe power leads, drilled a couple one inch holes in the headlights and reverse lights, popped in the strobes, then hooked them to the power supply. I took my time and spent about 4 hours on the project but I dont see why it couldn't be done in about two or three hours. I've seen kits on ebay. The strobes are extremely bright, I'll see if I cant figure out how to get a better video and post it later.
Old 12-19-2005, 11:13 AM
Sounds like the same thing almost! I did do the rear on the bike as well! It is a hard thing to capture on vid, I will agree!
Old 12-19-2005, 10:51 PM
06SUT23 06SUT23 is offline
06SUT23 is off the scale
if its for show you could alway put some strobes in your a/c vents.
looks good
