05-15-2012, 11:09 PM
Re: Relocate Rear Licence Plate
Hi the led light is countersunk so it looks factory, also around here if the cop wants to he can give you a ticket for it being cover up abit. I hope you got the spare tire carrier and the spare tire even if you don't use it.
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
24 inch Starr 770 Hammer Rims
Gen 6 Lockpick
Gm bluetooth
Front + Rear Camera's
2005 Screamin Eagle, E Glide
http://twrbaggersplus.com/
05-15-2012, 11:32 PM
Yep.I got the carrier and spare.What a bitch of a heavy piece of iron it was for one person to lift out the back side door without hitting anything.I gotter done though.I must have had a bowl or two of Weaties that morning..Did you mount your licence plate there with the light,or was it already on.I have to move mine away from the tow hook bolt,or the fuzz will nab me.Let me know where you got the parts to hook it up there.I deff like the looks of the plate there for shure.
05-15-2012, 11:54 PM
Hi i installed it myself,i milled the holes for the lic plate and the light at the top. I also used a factory gm weatherpack plug and tapped { soldered} into the clearance lights so if you ever need to change the led it just unplugs, i think it took me about 4 hours start to finish. I bought the led form a local parts store i deal with i can't remember the brand name. Be Glad you got the tire and carrier because it nice to have and cost alot!!!
Thanks Tracy
2008 H2 SUV
MC2 Roof Light Bar
Gen 6 Lockpick
Gm bluetooth
05-16-2012, 02:39 AM
I have the same spare tire eliminator kit and you can remove the bolt caps from the tow hooks and it would make the plate a lot more visable.
05-16-2012, 04:02 AM
What about useing 2xSUPER WHITE HIGH INTENSITY LED LICENSE PLATE BOLT LIGHTS .This is there ad:One brand new pair (2 pc.) of WHITE LED license plate/frame bolt lights that produce a super high intensity WHITE LED beam. These bolt
lights fit almost any motorcycle, atv, scooter car or boat. Connects to your license plate lights or any 12 Volt source. Easy installation.
?2 chrome bolts with SMD light(bolt head 1/2 inch wide and 7/10 in length. Threading is 3/5 inches in length. bolt head and threading combined
length: 1.25 inch)
?15 inches of wire (15 inches including LED bolt)
?Connects to any 12 Volt source.I was thinking of getting some of these led licence plate bolts to fasten the plate on the rear hatch black centerpiece.Think this will work.Any ideas..
05-16-2012, 01:57 PM
length: 1.25 inch)
That's very interesting...those would be perfect for my trailer. Nice find!
CNTRY
DTOM
05-16-2012, 03:32 PM
I agree you need to move that plate. It looks funny down in the corner with that big empty spot where it SHOULD go.
I used those LED license plate bolts on my motorcycle. I only use one, the first one had faulty wiring so I replaced it with the second one (they come in pairs) and its been working fine for a couple years now.
I would think using a clearance light for power instead of the current license plate wire would be MUCH easier.
Hybrid Mode
