08-13-2006, 11:18 AM
Re: Shorter Antenna
I have an antennax installed. I didn't like the big whip antenna when I first got my H3.
The shorter antenna works fine. However there will be a reduction of some radio reception, but since I mainly listen to XM it really doesn't matter much to me.
08-13-2006, 03:32 PM
Re: Shorter Antenna
08-14-2006, 03:53 AM
Re: Shorter Antenna
I have the same problem...l have removed the antenna several times since I don't use AM/ FM much. But it also helps to gauge the height of parking garages /etc. I am on the fence about the short antenna.
2006 Boulder Gray H3 / Adventure / Auto / XM / Side Steps
Previous:
2004 Nissan 350z
2002 Jeep Wrangler Sport
1997 Honda Accord EX
1994 Jeep Wrangler Sport
1980 MGB
08-14-2006, 03:56 AM
Re: Shorter Antenna
I went with this one:
http://snipurl.com/uwc1
Thanks for all the responses....I really appreciate you wealth of knowledge here on the hummer forum....
08-14-2006, 06:45 AM
Re: Shorter Antenna
The long antenna is a great gage for parking garages. It does unnerve you a little bit when you start hitting the ceiling with it, but is better than scraping the roof.
08-14-2006, 05:24 PM
Re: Shorter Antenna
auto zone or pep boys, look for the universal small whip. 12 bucks and your done
08-14-2006, 07:53 PM
Re: Shorter Antenna
I've tried two of the antenna listed above and I really don't want to knock any brand names or vendors, but they are crappy.The rubber one gets permanently bent like a pretzel as soon as you do 50mph.My best advice is "you get what you pay for".I personally would spend a few extra bucks and purchase a quality item.
War is not hell...it's worse
08-14-2006, 07:57 PM
Re: Shorter Antenna
I'm poor white trash, works for me, looks like I'm traveling fast all the time
08-14-2006, 08:02 PM
Re: Shorter Antenna
I agree, so which "quality" one would you suggest?
08-14-2006, 08:28 PM
Re: Shorter Antenna
I have xm so I dion't listen to he radio that much, but does the shorter antenna get as good of reception as the long one?
08-14-2006, 08:39 PM
Re: Shorter Antenna
White Trash...no way,they'd use a coat hanger
08-14-2006, 08:47 PM
Re: Shorter Antenna
Mine hits the bottom of the garage door when I pull in or out. There's nothing for it to snag on, so aside from the clatter, I figure it won't do any harm. I'm in a fringe area and don't want a stub antenna. I worry more about my roof rails, which sometimes catch a little door edge too.
'06 H3 Adventure (9/2005-1/2013)
08-15-2006, 10:29 PM
Re: Shorter Antenna
Originally Posted by blindzebra
... does the shorter antenna get as good of reception as the long one?
I'd like to know this too.
08-15-2006, 10:46 PM
Re: Shorter Antenna
No.
In urban areas, like Denver you really can't hear much of a difference since there are a lot of high powered radio transmitters close around. But out in the sticks (where you're listening to stations further away) the short antenna doesn't do as good. I'd guess at about a 20% - 25% reduction in long range reception.
08-15-2006, 10:47 PM
Re: Shorter Antenna
I have had the antennax one for 9 months now. I never noticed a change in reception quality. I have been pleased with the functionality and the look. No complaints. I have had no problems with reception.
08-15-2006, 10:49 PM
Re: Shorter Antenna
It has not bent either, still straight.
08-16-2006, 05:06 PM
Re: Shorter Antenna
I purchased my stubbie antenna from antenna-x on ebay(about $13.00).
the reception seems to be every bit as good as the factory antenna.
And it's very cool!
08-16-2006, 05:14 PM
Re: Shorter Antenna
And it's very cool!
I like the red top it matches
I dont mind the long antenna it warns you of low branches
08-16-2006, 05:26 PM
Re: Shorter Antenna
I was told that if i lose some weight my antenna would not seem so small
