Old 11-16-2005, 10:39 PM
DO IT.
Before I put my lift on my H2, my gas mileage was roughly 11-12 mpg. That was driving mostly city, minor highway.
When I put the lift with the 38's on it, my mileage immediately went from the 11-12 mpg to 8.6-9.1 mpg.
My logic was to install 4.56's which would bring the truck as close as possible to the stock configuration.
Point is, though I only installed them this weekend, I am averaging 11.0-11.5 mpg with way more power.
Excluding the labor because I did it, I've got less than 700 bucks in it. At a 2-3mpg increase, it won't take long to cover the cost of the gears.
Anyway, DEFINITE improvement, well worth the effort and money.
Mark
DO IT.
Mark
Old 11-16-2005, 10:51 PM
MUH_HUM MUH_HUM is offline
MUH_HUM is off the scale
I'm running 37's (no lift) and noticed no difference in mpg....Still @ like 12.
Old 11-17-2005, 02:39 PM
1BADH2 1BADH2 is offline
1BADH2 is off the scale
OC, what make did you install? I want to do that this spring my H2 doesn't like to move my 41's
Old 11-17-2005, 04:22 PM
kdio kdio is offline
kdio is off the scale
I waited a long time before I finally changed the gears. Huge difference, wished I did it sooner. I also went with 4.56 gears.
Old 11-17-2005, 07:26 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by MUH_HUM:
I'm running 37's (no lift) and noticed no difference in mpg....Still @ like 12. </div></BLOCKQUOTE>
Did you change your gears? (I'm assuming you did) Do you ever tow anything? Is there a difference in power?
Old 11-17-2005, 07:28 PM
rvs9 rvs9 is offline
rvs9 is off the scale
OC,
Where did you get your gears?
Old 11-17-2005, 07:44 PM
Did you change your gears? (I'm assuming you did) Do you ever tow anything? Is there a difference in power? </div></BLOCKQUOTE>
I'm astounded that he didn't notice any difference in power. Granted, they are a little smaller than the 38's but still, it wasn't even close. God forbid I try to tow anything.
Old 11-17-2005, 07:58 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content">Originally posted by rvs9:
OC,
Where did you get your gears? </div></BLOCKQUOTE>
Got the gears from this place. http://www.accuautoparts.com/index.jsp
Was just under 700 for gears, pinion bearings and minor install kit. (MAKE SURE YOU GET RACES WITH THE PINION BEARINGS. read my post today http://elcova.com/groupee/forums?a=tpc&s=2826088551&f=6...271025641#92710256 41 )
