Old 09-04-2007, 12:13 AM
morgansdaddy2004 morgansdaddy2004 is offline
morgansdaddy2004 is on a distinguished road
Default fuel tank removal question
can someone tell me how to disconnect the electrical connection on top of the fuel sensors( i think...its the big connection on the top of the tank)?
it looks to be the biggest plug.
Old 09-04-2007, 12:19 AM
Grizzy's Avatar
Grizzy Grizzy is offline
Grizzy is on a distinguished road
Default Re: fuel tank removal question
From the Magnacharger installation manual:
Disconnect the large electrical
connector on the top of the tank by pulling
back on the gray lock tab and squeezing
the end of the connector. Disconnect the
tank pressure sensor connector by lifting up
on it?s lock clip and pulling back on the
connector.
12/05
Hope this helps
Old 09-04-2007, 01:25 AM
It's a single black plug, with a red connector on top. I'm still not seeing how to remove it.
I took some pics but they are too big to attach...I have no idea how to resize them. Jesus, I go from one problem to another.
Old 09-04-2007, 02:53 AM
I think I got the pics attached.
Old 09-04-2007, 03:22 AM
ttkresurfacing's Avatar
ttkresurfacing ttkresurfacing is offline
ttkresurfacing is off the scale
Grady,
I bet if you look at page 6,7, etc. of this manual you can figure it out.
http://magnusonproducts.com/pdf/manual-HummerH2.pdf
Hope that will help.
Tim
Old 09-05-2007, 12:28 AM
Thanks for the help Tim. The good news is I finally got the tank out. The bad news is I think I need a new tank.
I don't know of a cheap fix and these tanks look to be close to $1000. I've attached some pics of what I found.
I don't see where the elbow was rubbing on the body-no idea how it got so chewed up.
