Old 12-25-2007, 11:15 PM
porschett's Avatar
Default Disc Brake Milage
I was wondering what kind of milage any of you are experiencing before you have to change the pads. I'm starting to get a squel out of mine like it's the wear indicators.
2009 H2 Hummer It's here!!
2006 Baja Performance 88 MPH
2008 GT2 Porsche
2009 DBS
Old 12-25-2007, 11:25 PM
tower's Avatar
tower tower is offline
Default Re: Disc Brake Milage
~50K miles of hard on & off road. Still good on originals!
Old 12-25-2007, 11:31 PM
porschett's Avatar
Thanks, thought it was a little early with only 15K. Must be dust buildup, I'll take her out and hit em!
2008 GT2 Porsche
2009 DBS
Old 12-26-2007, 04:14 AM
Tex_h2's Avatar
Tex_h2 Tex_h2 is offline
Huh, that doesn't sound right.........almost 70,000 miles and still no (knock on wood) problems....
Old 12-26-2007, 03:49 PM
MVR 155's Avatar
MVR 155 MVR 155 is offline
I have noticed some squeal over the hot summer months after the wheels start to show brake dust. Im guessing that due to the size/weight of the H2 that the pad compound is a bit on the aggressive side... these types of pads will produce a squeal after some dust build up. My stock brakes on my Z06 would start to squeal after about 50 or so miles of hard driving. Probably wouldnt hurt to pull the wheels for inspection (I have seen calipers hang up and prematurely kill a brake pad) but I am willing to bet its nothing to worry about.
1/4 mile: 11.661@118.86
2013 Audi S4
2002 Yamaha YZF R1 Blue/White
1/4 mile: 10.51@136
2005 Sea-Doo RXT
Old 12-27-2007, 12:31 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
I have seen them last for over 200,000 km. they should be taken apart and cleaned from time to time. Lube the slide pins with silglyde(silicone based lube) as well you can lube the backing plates of the pads which will help eliminate squeal caused by the steel pads vibrating against the caliper. Also clean and lube the steel sliders.
Old 01-06-2008, 04:57 AM
tjwheels tjwheels is offline
tjwheels is on a distinguished road
I was at my dealer a couple weeks ago (oil Change) and we talked about this very thing. He told me they have changed one set of pads prior to 100,000 miles and it was at 85,000.
Old 01-06-2008, 11:38 AM
porschett's Avatar
Thanks for the replies, I took care of the problem. Tokk her up to 80 mph and hit the brakes as hard as possible. No more squeel!!
2008 GT2 Porsche
2009 DBS
Old 01-06-2008, 05:39 PM
The dealer tech swears that they can go 100k. I had them changed around 50k prior to a Moab trip with Lion's Back on the agenda, though. Never can be too careful on that obstacle when it comes to the brakes.
Old 01-08-2008, 03:10 PM
pdsq99f4 pdsq99f4 is offline
We've never had to replace a set of brake pads on an H2. The ocasional brake squeak is usually fixed the same way you did.
Old 01-18-2008, 04:35 PM
HUM GOOD's Avatar
HUM GOOD HUM GOOD is offline
HUM GOOD has a little shameless behaviour in the past
98,000 on original set!
