Old 08-13-2005, 11:34 PM
BB BB is offline
BB is an unknown quantity at this point
Does anyone know which wire I can get a speed pulse signal from ?
BB BB is offline
Old 09-20-2005, 08:25 PM
Lucci Lucci is offline
Lucci is off the scale
a green and white wire. But there may be 2 of them. When I had my Navi installed I was getting and error that there was no Speed pulse signal. The installer fixed it and said they were to tap into a green and white wire; there were two of them and they had chosen the wrong one. (too bad for me they didn't at least test the system out after the installed it.)
Old 09-21-2005, 11:04 AM
BB BB is offline
Lucci, I would appreciate if you could tell me exactly where those green and white wires are located. Are they from BCM and PCM ?
Old 09-21-2005, 02:03 PM
h3\'er h3\'er is offline
h3\'er is off the scale
See this thread
I used the Yellow Wire
http://elcova.com/groupee/forums/a/tpc/f/2706067735/m/4...761018731#8761018731
Old 09-22-2005, 12:08 AM
<BLOCKQUOTE class="ip-ubbcode-quote"><div class="ip-ubbcode-quote-title">quote:</div><div class="ip-ubbcode-quote-content"> Lucci, I would appreciate if you could tell me exactly where those green and white wires are located. Are they from BCM and PCM ? </div></BLOCKQUOTE>
I will ask when I drop it off tomorrow evening
Old 09-22-2005, 01:56 AM
BB BB is offline
Thank you for the information, but I'm confused now. Please help. Do I need to tap into two wires or just one ? What is the difference between VSS High Signal and Low Signal ? Is there any other wires I can get from either BCM or I/P ?
Old 09-22-2005, 02:03 PM
No just 1 the yellow wire. VSS low is the ground side of the circuit
Old 09-22-2005, 11:55 PM
BB BB is offline
Thanks, h3'er.
