Old 10-24-2008, 05:39 PM
MaineH3's Avatar
MaineH3 MaineH3 is offline
MaineH3 is on a distinguished road
Default Wiring Off Road Lights
Hey everybody, I hope someone on here can give me some advise. I recently bought (4) Hella FF75 lights. The main reason I bought these are because of their low profile; they are going on a custom lightbar I am having made.
So, here are my questions. What gauge wire should I run off my battery to power these and what size fuse directly after the battery? I plan on splitting the wire and running to (2) relays to power the (2) sets of lights; they each are rated at 55 Watts.
The Hellas came with the relays, switches, connectors and wires. Unfortunately they did not label the wire so I have no idea as to what gauge it is. I am assuming it is 16 gauge, is that correct?
Any help is greatly appreciated.
Thanks,
Luke
MaineH3
'06 - Superior Blue Lux. H3
Old 10-24-2008, 09:26 PM
theJARRETconcept's Avatar
theJARRETconcept theJARRETconcept is offline
theJARRETconcept is on a distinguished road
Default Re: Wiring Off Road Lights
Try this:
http://www.hella.com/produktion/Hell...ngDiagram1.pdf
its a diagram that might be able to help you.
2009 Hummer H3T Alpha
Carbon Black / Off-Road Suspension with Front & Rear Lockers
Old 10-24-2008, 09:39 PM
MaineH3's Avatar
Originally Posted by theJARRETconcept
Try this:
Thanks man. I have that diagram printed off. Basically from that diagram I am going to combined the wire coming off the battery and then split after the fuse to the two relays.
I think I am going to go with a 30 Amp fuse as that is twice the one shown and go with the appropriate gauge wire from the battery.
Appreciate the help.
Luke
MaineH3
Old 11-10-2008, 07:58 AM
dbphotos's Avatar
dbphotos dbphotos is offline
dbphotos is on a distinguished road
Remember that by going with a 30amp fuse instead of a 15amp fuse you are taking away some of the protection that the fuses offer your lights. Better to blow a fuse than a light.
David - Victory Red H3 Wilderness
| David Bailey Photography | Digital Racing Images | Sports Shooter | flickr |
Old 11-10-2008, 02:52 PM
MaineH3's Avatar
Understood. I wired them up a couple weekends ago. Went with one 30 amp fuse, 2 relays, four lights and 1 switch. Works great.
MaineH3
