Old 06-12-2011, 02:29 AM
Rob 4092xx Rob 4092xx is offline
Rob 4092xx is on a distinguished road
Default Speedometer and Speed Sensore help needed!
The speedometer needle in my 2009 H3 is bouncing all over the place. I had this same thing happen in another vehicle I owned and ignored it as everything else was working properly. Eventually, the speedo needle became detached from the speedo and I had a real mess on my hands! The culprit turned out to be the speed sensor!
Well, deja vu!. Can someone please tell me where the speed sensor is for my H3? I want to get it replaced asap before my speedo breaks.
Thanks everyone!
Old 06-12-2011, 02:56 AM
HUMTECH's Avatar
HUMTECH HUMTECH is offline
Default Re: Speedometer and Speed Sensore help needed!
Vehicle speed sensor is on the back right side of transfer case just ahead of the driveshaft output
1998 Chev Z71
2007 Chev Trailblazer SS
Old 06-12-2011, 02:58 AM
Do I have to crawl underneath to reach it? Is it easy to get to? Do I have to remove the skid plate to access it? Is there a plug I have to disconnect? Thanks>
Old 06-12-2011, 02:59 AM
HUMTECH's Avatar
I would inspect wiring to the sensor thoroughly before replacing the sensor, more like to have a partial break in a wire than have the sensor go bad. Give the wires at the connector a firm pull and if they start to stretch you have an internal break in the wire. Check for chaffing in the harness as well.
1998 Chev Z71
Old 06-12-2011, 03:00 AM
I am not real good at figuring this kind of stuff out. Can you please be a little more discriptive where the speed sensor is? I really appreciate it!
HUMTECH's Avatar
Yes you need to get under it, there is a connector right on the sensor. shouldnt have to remove any skidplates, been awhile since ive seen one personally going by memory
1998 Chev Z71
Old 06-12-2011, 03:03 AM
HUMTECH's Avatar
Round sensor on the tailshaft of the transfer case with a 2 wire connector. right side facing about 15 deg down towards the ground
1998 Chev Z71
Old 06-12-2011, 09:04 PM
3Hummer's Avatar
3Hummer 3Hummer is offline
not sure if this is related to the issue your having but when i had my "07 H3 at one point the speedometer, and tachometer. stopped working. no matter what happened both would read "zero" always had to take it in and have the whole cluser replaced
2017 VW Jetta S
2012 Cessna 182T Skylane
/''T''|[___|___]
[---T--L -OlllllllO-]
()_)"""()_)/"**"\)_)
