02-17-2004, 04:48 PM
Hi,
For a certain reason I need to disable the mileometer on my hummer h2 while I drive it from the port to be tested as a new vehicle import as I need to keep the mileage below 350. Is this easy to do. Does it run off the gearbox or can I take a fuse out.
thanks
Scott
Hi,
thanks
Scott
02-17-2004, 07:35 PM
Why don't you put it on a flatbed or have it towed?
S&B Member since '03
02-17-2004, 07:46 PM
Sounds like bull****
02-17-2004, 07:48 PM
For whatever reason, it's still Wrong!!!
www.meatspin.com
02-17-2004, 09:29 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Scotty:
...as I need to keep the mileage below 350. Is this easy to do...<HR></BLOCKQUOTE>Very easy to do. Here is the simple explanation. Do all of your required driving and do your best to make sure the mileage does not go over 349. Simple and easy fix to your problem.
02-17-2004, 11:03 PM
Yes this is very easy to do. All you have to do is order a new dash cluster for your H2 and then take the stock one out, but all the miles on the truck you want to and then reinstall the stock dash cluster. You will then have the original miles on the vehicle and only the tech will be able to tell if they ever check the computer. Should cost you about $379 for the cluster, you should check out ebay or something like that. Good luck.
02-17-2004, 11:13 PM
Cant you just drive backwards for a while?
"Dont be the next anything...be the first something."
www.fixmyprinter.com
People Who Annoy Me...NAGGERS
02-18-2004, 02:45 AM
No Ferris, that doesn't work!
www.meatspin.com
02-18-2004, 12:01 PM
How about this. Mount a mirror at a 45 D angle above the odometer and then it would at least read backwards.
02-18-2004, 12:47 PM
That'll probably work, as long as the dealer falls for it!
www.meatspin.com
02-18-2004, 05:06 PM
thanks for the replies, I now have a soloution but am not going to share it with you,
many thanks
Scott
02-18-2004, 06:15 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Cant you just drive backwards for a while?<HR></BLOCKQUOTE>
Yes! Driving backwards will work!!! I know that for a fact because that's what they do in Canada. It was Dennis who told me...so it must be true
I'm a little confused though and thought that maybe some of you experts out there can clear up a technical question for me...Is the mileometer that little doohickey thingamajig that's on our dash where the rev-o-meter and speed-o-meter are located? And if I'm not mistaken, I think that our H2's are also equipped with a temp-o-meter too? But the part that's really confusing me is where our odometer is located...does anybody know???
02-18-2004, 09:43 PM
Well my gas-o-meter must be broke cause it always seems to read empty.
02-19-2004, 12:41 PM
<BLOCKQUOTE class="ip-ubbcode-quote"><font size="-1">quote:</font><HR>Originally posted by Alec W:
TJ, why would you make fun of the guy because he refers to an odometer as a mileometer?. That's what an odometer is called in the UK. The device records miles thus mileometer.
You are the first to jump on peoples asses for making fun of others but I guess it’s ok for you to do that. Hypocritical little b**ch aren’t you?
S&B Member Since 2003 <HR></BLOCKQUOTE>
If seems as if you might have taken this in the wrong way Alec and a way in which it was definitely not intended. I was just having a little fun with words, and it was directed at words and words only. Ever seen that great monologue Gallagher does about words and the English language? Absolutely hilarious! Oh well, I guess you're telling me that I'm no Gallagher, so please accept my apologies if I have offended either you or any of the others on this forum by playing around with words like that.
