Old 04-15-2009, 04:32 PM
kchummer's Avatar
kchummer kchummer is offline
kchummer is on a distinguished road
Default Oil pressure and voltage meter readings....
after getting the H2 warmed up and at a standstill what's everyone's oil pressure reading as well as voltage meter status....When I start mine cold the oil pressure is just above half way (40)....after driving and warming up then coming to a dead stop at idle it reads at about 30 (just under half) and the voltage meter reads just under half way also.....is this normal for the 6.0 motors??? my other pickup which has the 5.3 in it always reads at half or over half on both meters....just checking w/ everyone else....
Old 04-15-2009, 08:25 PM
kchummer's Avatar
Default Re: Oil pressure and voltage meter readings....
guess nobody pays attention to their guages.....
Old 04-15-2009, 10:44 PM
IRA51's Avatar
IRA51 IRA51 is offline
the gauges in these trucks (when they are working) are not very accurate ,so I wouldn't worry about it . the 6.0 is a great engine and will with propper mantinance go over 200 k .
A government big enough to
you have.
-- Thomas Jefferson
Old 04-16-2009, 12:28 AM
Guinnessboy Guinnessboy is offline
Guinnessboy is on a distinguished road
mine is exactly the same which is the way its suppose to be
